2004 Chevy Tahoe Flex Fuel
58,000 MILES • V8 • 4WD • AUTOMATIC
PHARDEN
I have a tahoe that runs on regular gas or Ethanol 85. The Ethanol 85 gives less miles per gallon but burns cleaner and gives better performance. Can I effectively raise the MPG by adding cold air intake and a new MAS? Besides these two options, you guys have any other ideas for raising the ethanol 85 MPG? Its a 5.3L V-8.Thanks!!
Mar 28, 2008 at 4:17 PM
BLACKOP555
  • 10,386 POSTS
a cold air intake will give you more power, and lots of people claim gains of 5mpg
and a new MAS sensor can help, especially if the old one is fouled.
also a new air filter that is high flow and a exhaust system true duals with high performance mufflers will increase gas mileage also as the engine will run more efficiently.
also some fuel system cleaner, properly inflated tires.
Mar 29, 2008 at 1:23 AM
