2004 Chevy Tahoe Fan Blows but no heat
136,000 MILES • V8 • 2WD • AUTOMATIC
JAKUGRE1
My fan blows, but there's no heat from front vents until RPM's are up. Stop at a light and vents blow cold air again. Sounds like vacuum problem? Also seems to be no hot air from rear vents.
Dec 10, 2009 at 1:51 AM
  • 110,248 POSTS
Actually, it sounds like low coolant. Have you checked to see if the engine coolant is full?
Dec 11, 2009 at 12:10 PM
JAKUGRE1
That's exactly what it was. A friend also had the same problem with his Ford, and I checked and filled the day after I posted. The guys who change our oil were supposed to be checking this. Guess we won't be going back there again. Thanks!
Dec 13, 2009 at 8:11 AM
