i change thew termostat and now i see leak this morning but dont see where its coming from do u think the timimng belt case can be leaking
Jan 29, 2009 at 11:41 PM
2CARPRO JACK
✓Experienced Mechanic
Ifit is up in fron tof the engine like that,it is probably the water pump. Get a bright flashlight and a mirror and look at the bottom of the pump, there should be a hole in it for coolant to come out of when it goes bad.Otherwise you should have it pressure tested so the leak can be found
