2004 Chevy Tahoe coolant leaking
2004 CHEVROLET TAHOE
70,999 MILES • V8 • 4WD • AUTOMATIC
SSAAGENT
i change thew termostat and now i see leak this morning but dont see where its coming from do u think the timimng belt case can be leaking
Jan 29, 2009 at 11:41 PM
2CARPRO JACK
  • 11,533 POSTS
Ifit is up in fron tof the engine like that,it is probably the water pump. Get a bright flashlight and a mirror and look at the bottom of the pump, there should be a hole in it for coolant to come out of when it goes bad.Otherwise you should have it pressure tested so the leak can be found
Jan 30, 2009 at 12:03 AM
