2004 Chevy Tahoe clicking sound
100,000 MILES • V8 • 2WD • AUTOMATIC
PRTTYBB6
My truck makes a ticking noise when i crank it up on the passenger side of motor but disappears after i drive it a little. Could it be vanish or slug and do it need to be flushed or stuck lifter caused from the vanish
Jun 17, 2008 at 1:54 PM
BLACKOP555
  • 10,386 POSTS
get your oil changed, does noise go away fro a little bit or stay the same no matter what?
could be a worn lifter or rocker.
Jun 17, 2008 at 3:14 PM
ANPHON
  • 9 POSTS
you might want to check your values. maybe your values needs to be adjusted.
Jun 19, 2008 at 12:54 AM
BLACKOP555
  • 10,386 POSTS
if the patterns are the same you are good to go! if not you may need a new engine or some modifications,
Jun 19, 2008 at 5:29 AM
