a/c stuck on defrost?
135,000 MILES • V8 • 4WD • AUTOMATIC
BRENDAMHILL
my battery went out yesterday...upon replacing the battery, the damper appears to have gotten stuck. I cannot get it off of defrost. I have turned it on and off, changed all the settings, and will only blows on a/c. It very hot here in Texas....please help!!
Aug 9, 2009 at 1:36 AM
DOCFIXIT
  • 18,828 POSTS
This is because the Mode vacatur is not working and needs replacement this guide will show you how.
Dec 4, 2019 at 12:28 PM
BRENDAMHILL
I actually fixed it...by turning off the ac while the truck was running, turning off the truck, removing a/c and hvac fuses, put fuses back in, start truck...let it run for a minute and turned it back on. Works just like it did beafore the battery went dead. But, thank you...
