2004 Chevy Tahoe
68,882 MILES • 6 CYL • AWD • AUTOMATIC
PACO878806
when i try to change the 4wd to any other it doesn't want to change and it stays the same . also when i try turning left or right it makes a rubbing noise and i press the gas to go and it doesn't advance what could this be
Apr 16, 2009 at 5:41 PM
PEAR69
  • 1,482 POSTS
Sounds like your tahoe is stuck in four wheel drive. That is why it will not steer properly. It could be a bad 4wd switch or the actuator motor on the transfer case might be bad.
Apr 19, 2009 at 2:14 PM
PACO878806
thank u that helped. So do u think this might cost me alot of money.
Apr 19, 2009 at 3:43 PM
PEAR69
  • 1,482 POSTS
A switch is not too expensive, but a transfer case actuator motor is around $350.00 plus labor.
Apr 19, 2009 at 3:46 PM
PACO878806
thank you....
Apr 20, 2009 at 4:46 AM
