fuel filter location and replacement instructions
22,590 MILES • V8 • 2WD • AUTOMATIC
JUAN GUZMAN 90650
Where is the fuel filter? I need to replace it.
Jan 6, 2009 at 5:10 AM
DOCFIXIT
  • 18,828 POSTS
This vehicle has a lifetime fuel filter built into the fuel sender inside the tank and thus is not serviceable separately. The fuel filter is not a replaceable part. If you do have a filter this video shows the job being done on a similar car but the process is the same.
https://youtu.be/CTv8UOiPjc0
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Jan 6, 2009 at 5:20 AM
TGROSCH
how do I remove the fuel filter from a 2004 chevy tahoe? I have the threaded end loose but I can't get the pressure fitting on the other side to release the filter
Jun 2, 2021 at 7:39 AM (Merged)
  • 75,988 POSTS
If this car has one the fuel filter in under the car. Here is a guide and a video to help you replace the fuel filter and release the lines:
and its for a different car but they have the same fuel lines.
https://youtu.be/Boi0DPXVHbM
Cheers
TGROSCH
Thanks! Worked perfect. I am all set. This site is great. ;)
  • 75,988 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers
  • 75,988 POSTS
You probably need this to remove it-check parts store.
ZONA99
Where is the fuel filter located on a Chevrolet Tahoe 5.3 liter engine four wheel drive
Thanks for your help
BRIAN 1
  • 1,030 POSTS
this fuel filter is not in the tank,this is not a returnless fuel sys. 05-to present is in the tank,this one is located on the frame rail below the drivers seat mounted on the frame. 04 was the last year for external fuel filter.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. If your Tahoe is a standard gasoline 5.3L engine the fuel filter is incorporated in the in-tank fuel pump assembly and thereby non serviceable. if your Tahoe is a Flex Fuel equipped 5.3L engine than there is an external fuel filter which is mounted on the left side frame rail and can be replaced. If the 8th digit of your VIN - vehicle identification number is the letter Z then you have the Flex Fuel option on your Tahoe and is thereby serviceable. Here is a tutorial showing how to replace an external fuel filter:
Here is a YouTube video showing how to replace an external fuel filter on a 2004 Tahoe with Flex Fuel filter:
https://youtu.be/G3PHPNYnXds
Hope this helps and thanks for using 2CarPros.
LATINADIVA509
How do I locate and replace the fuel filter??
BRIAN 1
  • 1,030 POSTS
https://images.2carpros.com/forum/automotive_pictures/147643_filter_2.jpg
The fuel filter is located on the right hand frame rail.
MARK THOMPSON
The fuel filter has a hose fitting on the outlet side. What is the secret for getting it loose?
Jun 2, 2021 at 7:40 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. This is a tutorial for you to view on how to replace a fuel filter:
I've attached picture steps below on how to replace the fuel filter and its location on your vehicle. Hope this helps and thanks for using 2CarPros.
PSTINE3224
Where is the fuel filter located in this vehicle?
JDL
  • 16,098 POSTS
The databases are not always correct. The one I looked at says, under the vehicle, driver side, attached to the frame rail, near gas tank. May be attached to inside of frame rail. Do not take any fuel lines loose without being sure there is no pressure on the fuel system.
ROM
How to change the fuel filter.
BLUELIGHTNIN6
  • 16,542 POSTS
This procedure requires the use of tool J-46363, Fuel Line Release Tool, or equivalent.
Disconnect the negative battery cable.
Relieve the fuel system pressure.
Raise the vehicle.
Remove the fuel composition sensor bracket nuts and reposition it aside.
Clean all the fuel filter connections and the surrounding areas before disconnecting the fuel pipes in order to avoid possible contamination of the fuel system.
Using a flare nut wrench and backup wrench disconnect the fuel line fitting from the fuel filter.
Use the Fuel Line Release Tool, J46363, or equivalent to disconnect the quick connect fittings as follows:
Pull the quick connect fitting back until the internal retainers hit the filter stop.
Twist one end of J-46363 and insert it between the fitting and the filter
Twist the opposite end of the tool and insert it between the fitting and filter
Once tool J-46363 is inserted, make sure it is parallel to the filter and fitting.
While holding the filter, push the fitting toward the filter in order to disconnect the quick connect fitting.
Remove the fitting from the filter. Remove the tool from the filter.
Slide the fuel filter from the bracket.
Inspect the fuel pipe O-rings for cuts, nicks, swelling, or distortion. Replace the O-rings if necessary.
To install:
Slide a NEW fuel filter into the bracket.
While holding the filter, push the fitting towards the filter in order to connect the quick connect fitting.
Using a flare nut wrench and backup wrench connect the fuel line fitting to the fuel filter.
Position the fuel composition sensor/bracket into place and secure with the bracket nuts. Torque the nuts to 13 ft. lbs. (17 Nm).
Lower the vehicle
CHARLIE498
where is the fuel filter and fuel pump located on my 95 tahoe
JDL
  • 16,098 POSTS
Hello, the fuel filter looks like this, should be located on inside frame rail.
https://images.2carpros.com/forum/automotive_pictures/170934_fuel_filter_3.jpg
The fuel pump is in the tank.
