Wheel Bearings?
135,000 MILES • V8 • 4WD • AUTOMATIC
WFALLER
My 03 Tahoe has about 135000 miles and brake pads are starting to squeal. I went to the auto parts store and picked up new brake pads and rotors, but the guy at the store said that I need to change the entire hub when I do the normal brake service. From what I have found in searching is that it is an enitre sealed assembly and cannot repack the bearings. I haven't felt anything in the front end that would indicate bearing wear. Is this a standard service item with a front end brake job or should I wait until they actually begin to show signs of wear??
Nov 17, 2008 at 12:01 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, here is my opinion and suggestion.....
Since it is a hub bearing assembly and a sealed unit, when you do the brakes check the bearings... just turn the hub by hand if you turn it and it feels smooth with no ruff feel to it and it doesn't fell loose when you move it up and down then I wouldn't replace it. If it does have some roughness or you just can't really tell then I would replace it.
Here is a video that shows you how
https://youtu.be/ZgiPRG6jffc
Hope this helps
Mark
Nov 17, 2008 at 1:03 AM
KISKI1996
I have a 2003 Chevy Tahoe Z-71 with 138,000 miles. I took it in for a tire change and rotation at a shop that was not my usual as my normal guy was very busy. They advised the frt left wheel bearing was bad and needed replaced. He ballparked it around $80. I waited to take to my regular guy and had him do it. When I picked it up we said he replaced the entire hub assembly and the total was $404, the hub being $256 of that. He said he could'nt just replace the bearing. Is there any truth to it being the entire hub assembly needed replacing?
May 18, 2020 at 7:56 AM (Merged)
PROTECH1980
  • 901 POSTS
The unit only comes as a sealed hub bearing assembly.
CARADIODOC
  • 34,413 POSTS
Yup. GM is famous for building their cars with "assemblies" that bolt on quickly on the assembly line but cost their owners more to repair later. That goes back to their HEI distributors and their generators in the '70s. The advantage was that the mechanics who didn't know how to diagnose the new systems could just replace one giant piece that had everything in it, but once the cars were out of warranty, the independent guys started figuring out how to replace just what was needed so they could save their customers money.
You are correct that the entire hub assembly must be replaced, but my question is why they recommended a new bearing if you didn't notice a problem? Typically they cause a humming sound, similar to an airplane engine. On GM front-wheel-drive cars there is a huge problem with the bearings getting a little sloppy, (nothing out of the ordinary), but that is enough to cause dropouts from the anti-lock brake wheel speed sensors. Those sensors are also built into the bearing so you get to buy that part too even if it isn't needed. I haven't heard of that signal dropout issue on the trucks. No other manufacturer I'm familiar with uses sensors inside the bearings although I'm sure there are some.
The first thing that got my attention was when you were told $80.00 for a new bearing. Not on any GM product. That was even a little high for an older Chrysler or Ford bearing but those took a long time and special tools to install so the labor was much higher. Your bearing can be replaced in less than an hour including a test drive. That is the advantage of the more expensive hub assembly.
A typical GM bearing costs in the area of $150.00 to $250.00. As a point of interest, the FWD car bearings WITH the ABS sensor costs a lot less than the exact same bearing without the sensor so we always buy the one with the sensor and just don't connect it if it isn't used on that car. The dealers' scrap metal bins are full of those wheel bearings. They are perfectly fine for cars without ABS, but the play they develop often occurs within 15,000 miles.
Did you notice any looseness in the wheel / steering, or was there any humming noise? I guess I'd like to know how they found a problem if you weren't noticing anything.
MEKELEE
What is the avg cost to replace wheel bearings on this type of vehicle?
BLUELIGHTNIN6
  • 16,542 POSTS
approx. $200 in labor only for replacing both rear wheel bearings.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1874.jpg
RPNESBITT
How do I change the front wheel bearning on the drivers side.
MERLIN2021
  • 17,250 POSTS
Remove the axle nut with truck on the ground, then jack up that side, remove caliper, slide off the rotor, on the hub will be a hole you line up on a bolt head, insert the socket, remove bolts(3), unplug ABS sensor wire, pull hub bearing out. You may need to tap it with a hammer.
https://images.2carpros.com/forum/automotive_pictures/62217_Hub_2.jpg
MERLIN2021
  • 17,250 POSTS
That info is for 2 wheel drive...
DINAIMANI
Tires and Wheels problem
1999 Chevy Tahoe V8 Two Wheel Drive Automatic
I have problem with wheel bearings . I have replaced these 3 times already . only one side is bad and that is front left side . what can cause this problem ?
May 18, 2020 at 7:57 AM (Merged)
RHALL77
  • 3,361 POSTS
may I ask what is it doing? is it making a noise or is there a ABS peoblem?
DINAIMANI
well last time I had to replace them they were crushed . it feels like grinding
RHALL77
  • 3,361 POSTS
are you using the same brand or different ones
DINAIMANI
brand new ones
RHALL77
  • 3,361 POSTS
I know they are brand new ones, but what brand are they. have you considered using a different brand and see if they last longer
DINAIMANI
which ones would you suggest ?
RHALL77
  • 3,361 POSTS
they are expensive but I would suggest the factory replacement from the dealer
