2003 Chevy Tahoe starts hard
103,000 MILES • V8 • 4WD • AUTOMATIC
MBAKER27
I have problems starting truck after it sits for a few days. If it don't start the first time you try you could spend five to ten minutes to get it started. This hapened a while ago could not get it started so I changed the spark plugs and that seam to help. But it is startting again and the spark plugs are far from needing replaced. It does seam though that it happen more when the gas is a quarter of a tank or less.
Thanks,
Mitchell
Nov 30, 2009 at 4:28 AM
JDL
  • 16,098 POSTS
Welcome to the forum, when the problem occurs, use a gage and check fuel pressure. 55-62 psi, key on engine off.
Nov 30, 2009 at 6:10 AM
