squealing noise that sounds like my serpentine belt going out?
2003 CHEVROLET TAHOE
ROBYNMOJO7
I have recently developed a squealing noise that sounds like my belt going out, but it is not constant. I happens when I get over 2000 RPM's and only when the AC is turned on. It also seems to happen when it gets hotter outside. I was able to drive to work this morning with the AC on LOW and it didn't squeal, but yesterday I couldn't turn the AC on without it squealing. Would this be the Belt or is it more to do with the AC???
Sep 2, 2008 at 1:37 AM
SQM
  • 6,383 POSTS
It does sounds like an issue with the ac belt. This vehicle does have a separate belt for the A/C, so it makes sense for it to squeal when the A/C is on.
A belt will make squealing noise when it gets glazed over and it slips under load.
Many times the belt will make noise with the A/C compressor being turned on as it puts more load.
Inspect the belt and replace if necessary.
Here is a helpful article on noisy belt:
https://www.2carpros.com/articles/car-squeaking-noise
Sep 18, 2021 at 3:33 PM
