2003 Chevy Tahoe Oil Sensor & Fuel gague
107,000 MILES • V8 • 4WD • AUTOMATIC
BERNIEJ
Having a problem with both the oil pressure and the fuel level gauge. Both seem to work some of the time. The oil pressure could probably be a bad sensor?? Both, when not working correctly, seem to peg fully to one side or the other. Could this be a sensor issue for both? Or could it be related?
Oct 7, 2009 at 4:04 AM
JDL
  • 16,098 POSTS
Welcome to the forum. How many gas tanks? What is the size of gas tank? Any codes? There could be some fuel level sensor codes?
Sometimes, I take the connector loose from the gas tank, use a resistor on the proper terminals for the fuel level sending unit. Turn key on, see if gage reacts differently to different size resistors. Some of the info I looked at shows the higher resistance, the higher voltage signal, sounds backward to me? empty-- 66 ohms, 1/2 tank-- 140 ohms, full tank 250 ohms. The voltage signal runs from 1 volt--2.5 volts depending on the fuel level. The info I looked at was for 26 gal tank, the specs are approximate. If the gage reacts properly, then everything from the connector forward should be ok and the problem is probably the sending unit in the tank. You need to test when the problem is ongoing and intermittent problems can be hard to track.
Oct 7, 2009 at 5:09 AM
BERNIEJ
The truck has one fuel tank approx 20 gallons. I'm unsure regarding to the codes, is this something I can dertermine without taking it to a shop? It seems both the fuel and oil gauges operate incorrectly at the same time. Yesterday both gauges where fully to the right..some times they work fine. Do you feel this problem could be related to both?
Oct 19, 2009 at 1:56 AM
JDL
  • 16,098 POSTS
Might be a problem with instrument cluster? Some of the national brand autostores will check some codes for free, don't know about manufacturer specific codes?
Oct 19, 2009 at 2:20 AM
