2003 Chevy Tahoe Idle drops below 500 RPM
83,000 MILES • V8 • 2WD • AUTOMATIC
ELEDESMA
I am having a problem with the idle of my 2003 Chevy Tahoe. Its a V8 5.3 L. When I start the Tahoe and the motor is on drive it idles at 500 RPM but it will drop to about 200-300 RPM's but never does it turn off. At this point when the idle drops below the 500 RPM mark the AC will blow hot air. So what I do is that I rev up the RPM's up to 1000 and the AC will began to work again. When the motor is on drive everything is ok. What can I do to fix the idle problem. Thanks
Jul 5, 2008 at 12:00 AM
2CARPRO JACK
  • 11,533 POSTS
Try cleaning the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. This should help stabilize the idle.That truck shoul dbe "drive by wire" ie, no throttle cable, if so then it doesnt have an idle air control valve which means you may have to replace the throttle bore to fix the problem, but try cleaning it first
Jul 5, 2008 at 1:13 AM
JYOUNT21
hey Jack.....where can I locate this motor you are referencing? I am having the exact same problem.
Jul 9, 2008 at 3:58 AM
2CARPRO JACK
  • 11,533 POSTS
If your truck doesnt have a throttle cable, you dont have one. If it has a cable it is located on the throttle bore. Clean out inside the throttle bore too, this will also help with the low idle
Jul 9, 2008 at 4:37 AM
JYOUNT21
I have verified that I don't have a throttle cable but the other type. Which direction would you point me in now?
Jul 9, 2008 at 5:10 AM
