2003 Chevy Tahoe fan removal
132,000 MILES • V8 • 2WD • AUTOMATIC
JAVINA
How do i remove the clutch fan from the water pump?
Sep 16, 2009 at 2:58 AM
PEAR69
  • 1,482 POSTS
You need a large adjustable wrench or wrench to fit the nut that is connected to the fan (where it bolts on the water pump). You need to hold the water pump from spinning and turn the fan nut counter clockwise to loosen.. Sometimes, a few swift wacks with a hammer is needed to loosen the nut...
Sep 17, 2009 at 5:46 PM
