You need a large adjustable wrench or wrench to fit the nut that is connected to the fan (where it bolts on the water pump). You need to hold the water pump from spinning and turn the fan nut counter clockwise to loosen.. Sometimes, a few swift wacks with a hammer is needed to loosen the nut...
Sep 17, 2009 at 5:46 PM
