2003 Chevy Tahoe Door Sensor
40,000 MILES • V8 • 4WD • AUTOMATIC
KEVINRYDEN
My information center is telling me that "right rear door is open" however I have open and shut it multiple times. It is definitely closed. Could this be a sensor of some sort?
Sep 11, 2010 at 10:26 AM
BMRFIXIT
  • 19,053 POSTS
Try this 1st
use a penetrating oil (WD40)and spray in the door latch close and open door few times and spray again
Sep 12, 2010 at 11:22 PM
KEVINRYDEN
I've tried that, but will try it again. Is there anything else to try before getting into part replacements?
Thanks for the help,
Sep 13, 2010 at 1:33 AM
BMRFIXIT
  • 19,053 POSTS
Next step should be to check BCM for codes and to do that you need a scanner tool
most common is that the switch stock and penetration oil should help (in most cases)
Sep 13, 2010 at 6:46 AM
