2003 Chevy Tahoe Auto Air Ride
72,513 MILES • V8 • 4WD • AUTOMATIC
EVEL1957
Had a message come up to service auto suspension. I had a GM tech check the Tahoe and he found a bad right rear shock. It had to many ohms. we replaced both rear shock with GM replacements. The repair code is gone. Before changing the shocks it aired the back shocks way up. The suspension still will not level and the rear come back down. I even took the air lines off the new shocks. The susoension will not lower in the rear and I think the front is ip as well. Any suggestions?
Dec 20, 2008 at 4:19 PM
RACEFAN966
  • 5,029 POSTS
Ok so tell me what you mean. If I am understanding correctly you are saying that the rear is higher then the front and it will not level out? This does have automatic air leveling on all four corners? You do hear the motor come one right? Get back to me with the info the more the better and we will take it from there. Thanks and Merry Christmas
Dec 23, 2008 at 2:00 AM
