the service four wheel drive message comes on. i have replaced the selector switch on the dash. i also replaced the transfer case control module and had it programmed by the dealer. i changed the fluids in everything. im down to maybe a transfer case motor or a speed sensor not sure. when i start it up the selector lights on the dash switch are supposed to stay where you left it but it has a mind of its own. it may start in low range, automatic, or really any of them, but what the main thing is when driving in 2 wheel after a block or so the transfer case kicks into neutral then i have to stop put the transmission in neutral then put it in auto 4 wheel to get to wherever im going. let me know.
Jul 27, 2009 at 7:28 PM
