engine it started shaking and it stall twice while i was getting in a parking space?
77,340 MILES • V8 • 4WD • AUTOMATIC
SHYGIRL
I have a 2003 Chevy Tahoe a month ago i was having problems with it, it started shaking and it stall twice while i was getting in a parking space the third time the car wouldn't start i had to jump start it.I took it to the Dealership they told me it was some cells inside the battery they replaced the battery and checked the alternator and told me that everything was fine i paid almost $300.00 Dollars.Now i'm having the same problem if i make a stop or get in a parking space it stalls, the RPM needle increases and decreases, i don't want to take it back to the dealership cause they charge to much money $80.00 fo a diagnostic and plus what it needs so i hope someone can give an answer.It cranks and starts but when i stop and get in a parking space the RPM needle goes up and down and most of the time it stalls when i get in a parking space.
Dec 13, 2007 at 1:01 AM
SERVICE WRITER
  • 9,123 POSTS
When it stalls now, it still does not crank (nothing happening when key is turned)
or
IT cranks but doesn't start up.
Dec 13, 2007 at 1:56 AM
  • 55,686 POSTS
This sounds like you have a throttle body that needs to be serviced or the engine has a vacuum leak, here is a guide to help you fix it and I have included a video so show you how to service the throttle body as well,
https://www.2carpros.com/articles/stall-at-idle
this video is on a avalanche but it is the same engine
https://youtu.be/Z3LDHdS1upo?si=6uegh2H4eEtcc3br
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Sep 9, 2024 at 9:23 AM
