2003 Chevy Tahoe
98,000 MILES • V8 • 2WD • AUTOMATIC
PAULCADBLUE
[img:080b0b7539]http://www.2carpros.com/forum/automotive_pictures/426907_DSCN0004_2.jpg[/img:080b0b7539]
Just had the rear breaks done, at FireStone ($650.00) new calibers, flush system done, now it feels like my foot is on the break while i'm driving , what can i do.
Oct 26, 2009 at 8:56 AM
DOCFIXIT
  • 18,828 POSTS
I would take it back $650 for rear brakes is alot of$$$
Oct 26, 2009 at 9:12 AM
PAULCADBLUE
Forgot to mention that I accidentally put steering fluid into the break fluid area
And I think that is what started this mess. Also I just spoke to another mechanic and he said that the only thing left if probably the Master Cylinder.
Oct 26, 2009 at 11:53 AM
DOCFIXIT
  • 18,828 POSTS
Well tah is a helpful bit of info. Did Fires flush out brake system front and rear? if so then what has happened is steering fluid has swelled piston seals in master causing piston to not retract. Also may have affected front calipers if steering was put in both resivors.
Oct 27, 2009 at 1:15 AM
