2002 Chevy Tahoe Rear A/C/Heat
117,000 MILES • V8 • 4WD • AUTOMATIC
ROGUE2259
Rear A/C works intermittently. When the rear air does come on the air is cold. I replaced the switch but that did not solve the problem. System is charged correctly and the front A/C works great.
Jun 7, 2010 at 9:23 AM
STUARTG14694
Have you checked that a/c gas is topped up to maximum and there are no leaks in connection pipes between rear and front. Not an a/c expert but just a suggestion. Sorry if this is not accurate at all.
Jun 7, 2010 at 9:37 AM
