2002 Chevy Tahoe power windows
106,000 MILES • V8 • 4WD • AUTOMATIC
BWHITE
My power windows for the passenger side have stopped working. They do not function from the drivers or the passenger doors, the master switch is not locked.
Nov 25, 2009 at 3:01 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd check the voltage circuits at the passenger side switch. Dark green wire is voltage to the switch. Black is ground. If that checks out, check the actual voltage and ground to the motor. The wire colors are brown and dark blue, because the motor is reversing depending on up or down, the wire colors switch between voltage and ground.
Sep 23, 2019 at 9:00 AM
