headlamps are not working.all other lights work.high beam indicator not working either
Aug 10, 2009 at 5:08 AM
✓Experienced Mechanic
Have you checked fuses? If they are good, you need to check for power to and from the switch. If you have it, then you need to check the highbeam switch for power to and from.
Aug 10, 2009 at 12:48 PM
CRAWLDADDY78
MEMBER
now they go on & off when I move the tilt wheel up & down.any suggestions?
Aug 11, 2009 at 12:46 PM
Either the switch is bad or there is a short in the column. Regardless, the steering wheel and part of the column needs to be removed to check.
Aug 11, 2009 at 3:23 PM
