2002 Chevy Tahoe Growling Noise coming from underneath the
130,000 MILES • V8 • 4WD • AUTOMATIC
DSK167
There is a growling sound that comes from underneath the truck. It happens "randomly" and seems to happen more since its been cold out. I had the drive shaft checked and CVs checked and they are fine. At first I thought it was a grinding bearing in the wheel - after replacing it I discovered that this was not the case.
The growling sound seems to growl at a certain point in a rotation - so the frequency of it is the same as the speed i'm going.
Any ideas?
Jan 16, 2010 at 11:39 AM
  • 110,246 POSTS
Have you checked the brakes? Also, can you tell me aprox where the sound is coming from, front, mid, rear...?
Jan 21, 2010 at 11:58 PM
DSK167
I took it to a differential guy.
There was a real light noise, like a soft rubbing noise. The guy didn't hear the heavy growl that would happen occasionally.
He thought the light noise was the front dif. bearings. (Which is was).
But once he opened up the dif., he found that the pinion was shot as well. and there a few teeth missing from the gear (The heavy grinding/growling noise).
thanks
Jan 22, 2010 at 4:05 AM
  • 110,246 POSTS
That will do it.
Jan 22, 2010 at 5:58 AM
