2002 Chevy Tahoe ENGINE DIES AT IDLE
2002 CHEVROLET TAHOE
105,000 MILES • V8 • 4WD • AUTOMATIC
RJABBONA
MY TAHOE IS OCCASIONALLY STALLING AT IDLE. I LOOKED FOR THE IAC VALVE PER YOUR SITE INSTRUCTIONS. I FOUND THAT MY TAHOE HAS AN ELECTRONIC CONTROLLED THROTTLE AND NO IAC VALVE TO BE SEEN. MY FRIENDS SAME YEAR TAHOE HAS THE TRADITIONAL THROTTLE BODY AND IAC VALVE. SO I WAS ABLE TO COMPARE AND SEE THE DIFF. DOES MY TAHOE HAVE AN IAC VALVE, AND WHERE? IF NOT, WHAT DO YOU RECOMMEND. THANKS, ROBERT.
Jan 26, 2009 at 6:18 AM
BRIAN 1
  • 1,030 POSTS
these dont have an iac,its all part of the throttle body.in 02 it was an opition to get drive by wire or a cable throttle.as far as stalling try cleaning the throttle body and mass air flow sensor,also have it scanned it might have a code.post back with what you find.
Jan 26, 2009 at 8:47 AM
