when doing a compression test on the cylinders, do you have to disable the ignition system? if so how do you do that? Sully
Apr 15, 2010 at 10:17 AM
BLUELIGHTNIN6
✓Experienced Mechanic
no ..just bump engine over with helper using gauge in each cylinder to record results.
Apr 15, 2010 at 11:55 AM
