2002 Chevy Tahoe abs module
130,000 MILES • V8 • 2WD • AUTOMATIC
ANGELA1970
The abs motor runs when my truck is turned off. I have been told that it is the abs module. If that is true. How do I replace it?
Jun 26, 2008 at 8:37 AM
DENNYP
  • 1,824 POSTS
Yes, it's a bad ABS module. Disconnect the wires from the module and remove the torx screws from the module. Lift the module off the valve assembly and be careful not to damage the solenoids when installing the new module.
Mar 16, 2021 at 2:39 AM
