2002 Chevy Tahoe
11,000 MILES • V8 • 2WD • AUTOMATIC
FOX561
hello my 2002 tahoe fuel pump stays on after the car is turn off. I replace the fuel pump relay and it is still on i even removed the relay and it is still on.I have to disconect the battery?
Nov 10, 2009 at 12:05 PM
1DODGE2
  • 21 POSTS
Are you sure its your fuel pump? Some Tahoes have ABS Module problems. Its located on the inside of frame by the drivers side. This relay when stuck in the on position will sound like the fuel pump and drain nthe battery overnight.
Nov 19, 2009 at 4:17 PM
