2002 Chevy Tahoe
TCRESTWELL
Noises problem
2002 Chevy Tahoe V8 Two Wheel Drive Automatic
Ok hers another question.My truck makes a wierd noise when it's at idle. The noise sounds like a motor turns on (coming from rear driver side sounds like) then it goes away. I thought it was from the truck trying to adjust to the weight in the rear, but it does it when there is no one or nothing in the back seat also. What is that noise and how do I fix it?
Nov 1, 2008 at 4:48 AM
DENNYP
  • 1,824 POSTS
If you have air ride, it is probably the air suspension pump. It will normally cycle on start-up.
Nov 3, 2008 at 1:40 PM
