2002 Chevy Tahoe
VQUEZADA
Noises problem
2002 Chevy Tahoe Two Wheel Drive Automatic 165000 miles
Hi, my 2002 chevy tahoe and the ABS light appeared on my dash and a humming noise came on once I turned the truck off (its been 5 hours and the noise is still on) but now my truck wont start. it sounds like something is stuck? any idea what maybe causing this problem?
Oct 3, 2008 at 7:11 PM
IEREMIA
first you need to pull out your abs fuse in the fuse box engine department, dont worry you'll still have brakes just not abs. that will shut that humming noise off other wise it'll run your battery dry which is causing your vehicle not to start. then, when you get time i would go online and find out how to repair the abs or take your vehicle to a abs specialist. hope this info helps. good luck.
Jan 6, 2009 at 11:50 AM
