how do you pull aprt the pumkin to pull out the axle
Nov 14, 2008 at 2:25 AM
DOCFIXIT
✓Experienced Mechanic
Undo the bolts drain lube. Then roll carrier around till you see small bolt. remove bolt Then push axle in till a C-clip falls out or you remove. Out comes axle. BE SURE NOT TO TURN CARRIER ASSEMBLY OR SPIDERS WILL FALL OUT . Reveres to install.
Nov 14, 2008 at 4:34 AM
