When using the truck after a few hours, when I start it up, it cranks up fine, but if I dont take off or press the gas while in park it will die out. Even if I do take off sometimes, when you make a sharp turn, it will die out. This only happen during the first 5 minutes of driving. After that everything is fine. I never have a problem starting it back up. If I go to the store for an hour or so and hop back in, no problems. Just when I let it sit for a while, the same problem starts for the first five minutes again-then everything is fine. Ive tried better gas in it, but that doesnt help. I had it checked before at an auto parts place for battery/alternator issues. They said I needed a new battery and the alternator was fine-I replaced the battery and and they ran the check again and said those two parts of the vehicle was good. Have any clue what it is?
Jul 6, 2009 at 6:20 AM
