2001 Chevy Tahoe Passenger window assembly
177,000 MILES • V8 • 4WD • AUTOMATIC
METRONEON
The passenger side window is not functioning. The motor was replaced about 6 months ago. We would like to see a diagram of how to repair/remove/install the window regulator, or how the relevant parts interact to correct this problem.
Sep 3, 2010 at 11:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
can you hear motor running when you press switch? does window work using master switch or individual door switch?
Sep 3, 2010 at 12:16 PM
