emergency brake on my vehicle goes all the way to the floor without engaging the brakes?
153,437 MILES • V8 • 4WD • AUTOMATIC
BOB KRUGER
The emergency brake on my vehicle goes all the way to the floor without engaging the brakes. How do I resolve this problem
Apr 3, 2009 at 3:43 PM
  • 110,248 POSTS
Two things. First, make sure the rear brake shoes are properly adjusted. Next, under the car you will find the steel brake cables. One will have an adjustment bolt. When you tighten it, it takes the slack from the cable so it works. The only other thing is you may have a broken cable. Here is a video of the job being done to help you.
https://youtu.be/uo1RnATyEok?si=o4Bm55xrJUFKoETF
Mar 16, 2021 at 2:59 AM
