AC not working
DAISY738
When I left to run errands today the AC was working fine. After the first stop, I got back in and it was blowing warm air. I was never able to get it to blow cool air again. Any ideas whats wrong?
Jun 28, 2010 at 2:07 PM
  • 75,988 POSTS
It sounds like the system is low on refrigerant but to be sure here is a video to show you how to check it
https://youtu.be/uZrQCGwXfek
this guide can help as well
Jun 28, 2010 at 2:15 PM
DAISY738
Not to sound like a dumb girl, but low and high pressures of what? Are you refering to having the ac on with the control?
Jun 28, 2010 at 3:39 PM
  • 75,988 POSTS
Okay I understand in other words have the freon/refrigerant checked, you start here
Jun 28, 2010 at 4:44 PM
SASSI_FRASS
My 2002 Tahoe is doing same thing. Compressor & clutch working fine. Small tube is ice cold but not freezinf. Freon gauge reads full. Had water in cargo area but after finding clogged drain and cleaning out, that problem is solved. Could there be another clogged drain causing my problem?
Sep 4, 2012 at 12:14 PM
RANDY SHARP
  • 165 POSTS
2001 chevy tahoe,having some ac issues system blowing warm air.I thought it might be the temp control switch but it was fine cable was good and the door under the dash was closing and sealing.But the other day i was checking the condenser for anything blocking it from getting air it was fine,then I started it up and now the compressor is not engaging and I want to put freon in it.So here is my question I know you can manually use a fused jumper wire by taking the ac relay out and running a hot from battery to a connection where relay is I need to know which one it is this truck has automatic climate control does anybody know? I do not have a manual
Jul 28, 2019 at 12:02 PM (Merged)
HMAC300
  • 48,601 POSTS
have a pro look at this if Freon leaked out ti won't stay long and you'll waste your money
RANDY SHARP
  • 165 POSTS
Hey thanks again but really what I need to know is I have to have that clutch engaged as I am adding the freon right,and I wanted to know if you knew what terminal it would be where the relay goes so I can run a jumper wire from there to the battery,so I can get the clutch engaged manually.I would appreciate it I don't have a manual for this truck.Thank you again
HMAC300
  • 48,601 POSTS
if you start to put the Freon in it may allow you to engage the clutch so it will take the rest in. the amound should have a sticker on the radiator if you need to jump it use the pressure switch on the accumaltor, but you probably won't as it fills or even with the first can sending pressure in it wil problably work. You really shouldn't do this though as it may only last a day or two anyhow.
RANDY SHARP
  • 165 POSTS
OK I know what switch you are talking about just unplug it and what terminal do I jump it to.Sorry for all the questions.I have learned alot from your experience.I really appreciate it.
HMAC300
  • 48,601 POSTS
yu just unplug it andjump form one sside ot the other, but if youget like 3/4 can in plug it back in
KEITH THOMPSON2
The compressor went out so i put a new one in then i refilled with r-134 and it started working fine one to two days later and the A/C clutch will not kick on anymore have done this twice. Now i went to add some more cause it stopped again and the gauge says the Freon is full but it will not turn on. any ideas on what this is the A/C is blowing hot air? before i changed the compressor out i changed the orifices in front and back of the vehicle so i would not think those are plugged.
RANDY SHARP
  • 165 POSTS
Ok thanks for the help on the ac it is fixed.Now I have another question for you. I have this 1981 cad sedan de ville getting no fuel to engine my manual does not show anything I need to know inside the cat it has 2 fuse boxes one of them holds the relays do you happen to know which one might be the fuel pump relay?It has a 6.0 8,6,4 motor DFI system.
CJ MEDEVAC
  • 11,000 POSTS
If the compressor shelled out and locked up, you may have debris in the lines.
Inspecting the first orifice in line may confirm this.
The Medic
HMAC300
  • 48,601 POSTS
boy you surelike punishment with that motor lol. see pic
  • 55,647 POSTS
I would use a test light and check for power at the compressor clutch.
This will let you know if the clutch coil is not working correctly or if there is some other problem we can hunt down.
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
R2BUFFALO
I want to add some A/C refridgerant to my system. Exactly where is the fitting to do this. On a 2001 V8 Tahoe
MERLIN2021
  • 17,250 POSTS
Look for the BLUE cap on the accumulator on the right side of the inner fender.
LEGITIMATE007
  • 5,121 POSTS
the correct fitting should have a blue cap, the red one is always the wrong one, so what ever color is the other one then that will be the correct one, because sometimes it will be black
MERLIN2021
  • 17,250 POSTS
The other thing is these recharge cans only fit the LOW side, it is larger in diameter than the high side, also charge with the can upright ONLY, or system damage can occur...
LEGITIMATE007
  • 5,121 POSTS
thats a very good point , thanks merl
MERLIN2021
  • 17,250 POSTS
glad to add!
RANDY SHARP
  • 165 POSTS
Have a 5.3 litre chevy tahoe.My air condiontioner is blowing warm air,I bought a can of the charge yourself, used the whole bottle but is still blowing warm air.Does anybody have a theory,and I can hear the compressor kick in just not blowing cold air.
DOCFIXIT
  • 18,828 POSTS
Maybe heeds more cool juice
WRENCHTECH
  • 20,760 POSTS
You really don't want to just arbitrarily add that junk to your system without knowing what the current level is or what additives and sealers that have been added to that can. You can easily ruin the whole system using those cans when you don't know what you're doing.
RMILL35
My Air works fine and then it will change and blow hot air for a while then switch back to cold air. Never know when this is going to happen and it is happening more often. What could be the problem?
Thanks,
Bob
  • 75,988 POSTS
Could be freezing up due to air and moisture forming into ice and blocking off the orifice tube-try having it vacuumed
