2001 Chevy Tahoe ac belt broke is it difficult to replace?
2001 CHEVROLET TAHOE
200,000 MILES • V8 • 4WD • AUTOMATIC
RT2802
MEMBER
1 POST
Jul 13, 2009 at 9:28 PM
✓Experienced Mechanic
I believe you have a serp belt (one belt runs everything). It isn't hard to replace, just follow the belt routing diagram under the hood. If you can't find it, let me know.
Aug 10, 2009 at 3:41 PM
INKEDUP
MEMBER
the ac has its own belt and tensioner. you can access from the bottom
Aug 10, 2009 at 4:16 PM
It is an easy one. Here is the belt routing diagram for it. Turn the adjuster to loosten the belt and then replace it. THe adjuster pivots. Take a look at this and let me know if it is the correct one and if it helps:
