2000 Tahoe coolant leak
JHUMP21
I have a 2000 Tahoe (103K) and have a coolant leak with no visible evidence of it leaking. I have to add coolant almost daily but particurally after long engine use. Could this be an intake gastket that needs replacement; diverter valve?
thanks!
Sep 25, 2007 at 3:01 AM
PEAR69
  • 1,482 POSTS
Did you fix this? If not stop running the motor or should I say recking the motor. The coolant is probably leaking inside of your motor. Drain and check your oil to be sure.. It's probably the lower intake manifold gasket..tahoes are famous for this!
Nov 3, 2007 at 5:20 PM
