2000 Chevy Tahoe Tranfer case
99,000 MILES • V8 • 4WD • AUTOMATIC
LDEAN
I have a 4x4 2000 Tahoe with an automatic transmission. When I put it in D or R I get a brief loud metallic noise which appears to be coming from the transfer case. To confirm this I placed the transfercase in natural and placed the transmission is D and R and got nothing. I then placed both the transfer case and transmission in Nautrual . Got under the car and turned both drive shafts at the same time and got an identical noise. Does this sound like I need to replace the transfer case, rebuild or what?? Or is my diagnose not even transfer case.
Sep 21, 2008 at 7:24 AM
2CARPRO JACK
  • 11,533 POSTS
It could very well be,but replacing wont be necessary.Sometimes the guides wear int eht-case and you get a slapping sound from the chain, depending on how much you use 4wd. This can easily be repaired by a trans or 4x4 shop. Are all u-joints in good shape?
Sep 22, 2008 at 12:34 AM
