2000 Chevy Tahoe fuel problem maybe??
13,200 MILES • V8 • 2WD • AUTOMATIC
JFA
Helllo: I recently noticed that my tahoe began shutting off after i drive it when its not fully warmed up is this normal ?, also after it shuts off it feels as if it needed fuel and it takes a few ckanks to stat up and it idles really low.
May 14, 2010 at 7:07 AM
HMAC300
  • 48,601 POSTS
check your fuel pressure. it should be at least 40p.s.i. if you have never change d you fuel filter change it. if you have low pressure then it may be the fuel pump stopping.
May 18, 2010 at 12:26 PM
JFA
Thank you for your response. This past weekend I went to Disneyland and I noticed that when I got back home, the TAHOE was working nice. And I still haven't checked the pressure is this weird or what??thank you again..
May 20, 2010 at 3:14 AM
