2000 Chevy Tahoe can one piston be replaced
134,000 MILES • V8 • 4WD • AUTOMATIC
DPRESGRAVES
My intake manifold was being replaced and the shop got a piece of metal into the #7 piston and beat it up pretty bad. They are going to replace the bad piston. Is that OK. I thought all pistons, etc. had to replaced at the same time?
Feb 12, 2009 at 12:32 PM
BRIAN 1
  • 1,030 POSTS
not all pistons have to be replaced,but when they replace the one piston you have to check the cylinder wall,if the metal scraped the wall to deep the block will be junk.have them check the cylinder wall if there are no scratches or light scratches you need to hone the cylinder wall.post back with any other questions.
Feb 13, 2009 at 3:27 AM
DPRESGRAVES
Thank you for responding. don p.
Feb 14, 2009 at 4:52 AM
