1999 tahoe ac water leak inside
1999 CHEVROLET TAHOE
ANDREW00400
i have a 1999 chev tahoe with 48000 miles that right the ac leaks water in on the pass side it is a 350 4x4 ac works great just drips water inside an in glovbox
Aug 13, 2007 at 10:03 AM
STPETER01
Andrew, It would appear that your a/c drain pan tube is plugged. Jack up your vehicle on the passenger front side. Slide under and look for a tube with an open end. It should roughly be about as far from the front as the windshield. Put your Shop vac to the end of the tube and it will usually suck out whatever is clogging the drain pan. You will hear when the plug get sucked out. Good Luck
Aug 13, 2007 at 12:39 PM
