1999 Chevy Tahoe transfer case
124,000 MILES • V8 • 4WD • AUTOMATIC
YARDMAN
i just replaced the transfer case on my truck with a used one. iam leakinhg alot of fluid from the rear of the case, where the drive shaft fits in. is there a seal there that needs to be replaced. if so is it easy to do
Oct 7, 2008 at 1:27 PM
  • 110,248 POSTS
Hi:
Yes, there is a seal that should be replaced. It's not hard to replace, but you must remove the driveshaft again. After that, you will see the seal. Remove it and replace with a new one. I always used a large deep well socket to get it in straight.
Oct 8, 2008 at 11:49 AM
