the ac blows but its not blowin really cold air what could be wrong
Sep 19, 2010 at 7:41 PM
✓Experienced Mechanic
Hi herberts, Welcome to 2carpros and TY for the donation
Check the high and low pressures-if okay could be the air blend door not fully opening if okay have the HVAC control module tested.
Sep 19, 2010 at 9:30 PM
HERBERTS
MEMBER
im not really understand bout Check the high and low pressures-if okay could be the air blend door not fully opening
Sep 19, 2010 at 10:55 PM
Checking the high and low pressures tells you about the amount of freon in your system, the air blend door could be stuck half way between heat and cold position and being mixed together, that's why its not that cold
