1999 Chevy Tahoe the AC blows but not to cold
HERBERTS
  • 1999 CHEVROLET TAHOE
  • V8
  • 180,000 MILES
The ac blows but its not blowin really cold air what could be wrong
Monday, September 20th, 2010 AT 2:41 AM
Hi herberts, Welcome to 2carpros and TY for the donation
Check the high and low pressures-if okay could be the air blend door not fully opening if okay have the HVAC control module tested.
Monday, September 20th, 2010 AT 4:30 AM
HERBERTS
Im not really understand bout Check the high and low pressures-if okay could be the air blend door not fully opening
Monday, September 20th, 2010 AT 5:55 AM
Checking the high and low pressures tells you about the amount of freon in your system, the air blend door could be stuck half way between heat and cold position and being mixed together, that's why its not that cold
Monday, September 20th, 2010 AT 8:47 AM
