1999 Chevy Tahoe Sluggish vehicle
79,189 MILES • V8 • 4WD • AUTOMATIC
TAHOE DADDY
Car has been storage for the past 4 yrs. When I hit the gas it feels like the vehicle is going to stall before it actually picks up power. I want to know what I'm in for before I take it to the shop.
Oct 5, 2010 at 1:22 PM
  • 75,988 POSTS
Could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 5, 2010 at 1:27 PM
