My truck would just shut off. No check engine light, however the dashboard light come on dim, both turn signal is lit solid and high beam light is lit. when I do turn on my lights, all lights on the dash turns off, but the chime still work. cranks normal, wont start. I plugged in a lower end OB2 scanner to see if it would give me something. Ironically, as soon as I plug it in, the dashboard goes to normal, truck starts up like its brand new, drive fine with the scanner still plugged in; unplug problem resurface. if u put a high end scanner(the 7-9 grand), the prob is still there, but the device reads no connection. after i took it home, I unplug the ICM, I hear all the modules cycle, like a reset. Plug it back in and I have a brand new truck (for 24 hrs it seems like). I did replace the ICM. it works well for 2-3 weeks, now the problem is back. any ideas before I start throwing away money.
Jan 6, 2020 at 7:25 AM
(Merged)
