Check the transmission fluid level. Remember to check it when the engine is warm and running. Low fluid level will cause this. Does it go forward and shift properly?
SPONSORED LINKS
Sunday, March 9th, 2008 AT 10:08 PM
LEMML
MEMBER
Fluid ok. Hesitates from 1st to 2nd others ok.
Monday, March 10th, 2008 AT 10:40 AM
PEAR69
MECHANIC
Sounds like the transmission filter is blocked up or one or two solonoids inside of the transmission are failing.
Monday, March 10th, 2008 AT 5:51 PM
LEMML
MEMBER
What is the price range to have this problem solved?
