1999 Chevy Tahoe ENGAGE
1999 CHEVROLET TAHOE
170,000 MILES • V8 • 4WD • AUTOMATIC
TEDDY BEAR
I HAVE A 1999 TAHOE, WHICH I WAS DRIVING ON THE HIGHWAY THEN ALL OF A SUTTON MY RPM WENT TO 5 AND I LOST POWER IN THE TRANSMISSION. I PULLED OVER FAST TURNED THE CAR OFF AND TRIED TO PUT THE CAR IN GEAR, AND IT WOULD NOT ENGAGE IN REVERSE, DRIVE OR 1 AND 2. SO WHAT COULD BE THE PROBLEM
Aug 8, 2009 at 6:40 PM
  • 110,240 POSTS
A sensor would have set a check engine light. If it has, have the computer scanned. If it didn't, you will need to have it checked by a trans mechanic. It could be many things, torque converter, ront pump... However, make sure the trans fluid is full with the vehicle running, normal operating temp, and in park.
Aug 10, 2009 at 1:04 PM
INKEDUP
  • 8 POSTS
the transfer case will also cause this to happen. is the four wheel drive light coming on?
Aug 10, 2009 at 4:20 PM
