1999 Chevy Tahoe response
1999 CHEVROLET TAHOE
22,000 MILES • V8 • 4WD • AUTOMATIC
CQX7514
I have a 1999 Chevy Tahoe and im experiencein violent shaking in the fron end while driving any where from 30 mph and up. I've had the powersteering gear box replaced and the symptoms got worse. I have an appointment to replace both lower ball joints, both drive axles, and to have it aligned. The mechanic states that uppers and tie rod inners and ends are good. If after replacing these, i still experience violent shaking, what should i do next.
Feb 16, 2010 at 6:57 PM
MACKKO10357
I have the same vehicle 1999 Tahoe, I had same problem, what was found and replaced were the pitman & idler arm (then all was well)
Mar 9, 2010 at 3:18 PM
