1999 Chevy Tahoe no spark
1999 CHEVROLET TAHOE
280,000 MILES • V8 • 4WD • AUTOMATIC
ALLEGANJIM
1999 tahoe, some times try to start and it has no spark, disconnect battery wait a while hook up and starts and runs fine. what can cause and is there a crank position sencor and where is it at. thank you
Aug 25, 2008 at 5:32 AM
PEAR69
  • 1,482 POSTS
The crank sensor is mounted to the bottom of the block just behind the crank damper.
Aug 27, 2008 at 6:09 AM
DOMEBOY31
Check the ground wire that goes to the engine block to the frame.
Sep 5, 2008 at 5:40 AM
